Discussion topic: Removing satellite doshes
Message posted on 13 Jan 2026 12:14 PM
Does Sky ever come and remove the satellite dishes once you change to fibre? I suspect not but thought I'd ask.
Message posted on 13 Jan 2026 12:16 PM
Re: Removing satellite doshes
@Tansley1 wrote:Does Sky ever come and remove the satellite dishes once you change to fibre? I suspect not but thought I'd ask.
No, it's your property after installation.
Message posted on 13 Jan 2026 01:06 PM
Changing your broadband to fibre doesn't negate the need for a satellite dish for your TV service, unless you have also switched that from Sky Q to Sky Stream.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 13 Jan 2026 01:38 PM
Yes moved from Sky Q to Sky stream
Message posted on 13 Jan 2026 02:10 PM - last edited: 13 Jan 2026 03:07 PM
Sky satellite television contracts transfer dish and dish cable ownership to the householder on installation specifically so that Sky isn't now responsible for tens of millions of the things installed over nearly four decades.
