Discussion topic: Remove Bluetooth device.
Message posted on 12 Jun 2023 02:32 PM
My old smartphone burned out and was destroyed. I cannot remove it from the list of Bluetooth devices on my Sky Q box.
Message posted on 12 Jun 2023 03:39 PM
Re: Remove Bluetooth device.
@AliGator wrote:My old smartphone burned out and was destroyed. I cannot remove it from the list of Bluetooth devices on my Sky Q box.
There is no device list on a Sky Q box so you can't remove (or add) any devices
To remove devices from your home network type 192.168.1.254 into a Web browser.
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 12 Jun 2023 04:04 PM - last edited: 12 Jun 2023 04:07 PM
Mmm.
Hi @AliGator
Bluetooth devices that are paired to the Q box are listed in Settings - Setup - Music
You can remove all devices by carrying out a Reset Settings in the Q box hidden menu.
Message posted on 12 Jun 2023 06:20 PM
@oldfellaahh got a bit mixed up there, thanks for the clarification
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 12 Jun 2023 06:36 PM
Message posted on 12 Jun 2023 07:21 PM
I have not needed Sky help for a long time and was very disappointed to find that what used to be a very good service has disappeared. Thank goodness tor sky community and people like @oldfella who are doing Sky's job for them and doing it so well.
Unfortunately I am unfamiliar with this app and have claimed an answer which his nothing but grateful thanks, but I do hope that Sky pick this one up.
Sky, if you provide the means of adding devices, the total number of which is limited, in an app, it is normal to provide a clearly seen way of removing them.
Thanks again @oldfella.
