Discussion topic: Remote
This message was authored by: Jasmin09
Remote
Sky q remote isn't turning tv on so having to use 2 remotes
Re: Remote
Hi @Jasmin09
Avatar for Jasmin09
Re: Remote
Hi thanks for instructions I've done this and it sorts the q box but it doesn't turn my telly on or off. I have to use the tv control to do this and also press the area that says sky on the screen . Then the sky control will work. So I'm having to use both controls . Does anyone know how I can just use the sky control for telly and q box ?
Re: Remote
When you paired your remote, did you do a search for your TV, as below?
If you are having trouble finding your TV, let us know the make and model and we will help you find it sometimes some mimic other TVs.
Hold down 7 and 9 until the remote's light flashes 4 times to factory reset your remote.
Then you need to pair it again:
  1. Hold down 1 and 3 together
  2. Select Continue and enter the brand of your TV
  3. Select Find it for me
Press the volume buttons on your Sky Q remote and see if this changes to volume on your TV. No luck? Select No, try another until you find the right setting.
