Discussion topic: Remote
Message posted on 12 Nov 2024 12:54 PM
Remote
Hi,
I recently got a replacement for my remote but needs
pair to the RV as I cannot operate most functions.
Message posted on 12 Nov 2024 01:09 PM
Re: Remote
Hi @CatherineOti Try following the help guide. https://www.sky.com/help/articles/setting-up-q-remote
Message posted on 12 Nov 2024 01:10 PM
Re: Remote
@CatherineOti wrote:
Hi,
May I suggest you try a reset of your remote: as a first step
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
