Discussion topic: Remote
This message was authored by: Cyber1
Remote
I've lost the ability to turn on my TV and sky box with one touch of the top sky button. How do I get it back?
Re: Remote
@Cyber1 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
Also check in the Q box under settings >setup>audio/visual that HDMI control is still set to on
Avatar for Cyber1
Re: Remote
Thanks for replying but no joy. Tried both suggestions but no change.
Re: Remote
Hi @Cyber1   In that case, something has changed on your TV preventing HDMI Control. Ensure that the HDMI cable is seated properly both ends.
