Discussion topic: Remote
Message posted on 24 Dec 2023 09:57 AM
Remote
I've installed a sky q mini box and all works fine the remote on the new bix now controls my TV upstairs.
But know the remote on the main sky q box does not work.
Message posted on 24 Dec 2023 01:21 PM
Re: Remote
Hi @Matt19711
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Message posted on 24 Dec 2023 02:29 PM
Re: Remote
all sorted👍👍
