Discussion topic: Remote won’t work on mini box
Message posted on 30 Mar 2023 07:43 PM
Our mini box won't switch o. With the remote. We have tried 3 remotes and non work. If we switch on manually we cannot access controls
Message posted on 30 Mar 2023 08:34 PM
Re: Remote won’t work on mini box
First reboot the mini.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the mini box (Amber led)
Then
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 07 Jan 2025 09:03 AM
Had the same and fixed it by buying an audio/visual fibre cable from Amazon for 8 quid which connects the mini box with the tv. Problem solved.
