Discussion topic: Remote not working
This message was authored by: Smash
Remote not working
My sky Q remote stopped working, I have now twice called the number I have been given and twice when the ai assistant booked me a new remote to come I have received a text half an hour later that they have been unable to process my request for a replacement remote. They then give me the number again that I called to get the replacement remote in the first place.
can anyone give me a number so I can get in touch with a human to find out what the issue is? Every time I call the ai assistant it ends the same way with me not getting a replacement remote and I want to know the reason why.
Re: Remote not working
@Smash
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
Hi @Smash
With the Q box on with green led try completly resetting the Bluetooth remote you have.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
