Discussion topic: Remote help
Message posted on 25 Oct 2023 10:53 AM
Remote help
How can I stop sky q remote operating my tv, I need to use the original tv remote but have failed to find a way to do it. The tv will only operate with the sky remote.
Message posted on 25 Oct 2023 11:01 AM - last edited: 25 Oct 2023 11:04 AM
Re: Remote help
Hi @sylvia46
This will unpair it from the TV and the Q box.
if you permanently don't want to control your TV you will need to re pair the Q remote to the Qbox
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes . You can then choose not to pair or pair to the TV again.
