Discussion topic: Remote control volume function
This message was authored by: AOB57
My SKY Q remote control has stopped adjusting the volume on tv
Re: Remote control volume function
Follow the instructions here to try and fix your remote: https://www.sky.com/help/articles/sky-q-remote-help
If these steps do not work, you can request a replacement at the end I believe.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
