Discussion topic: Remote control not working
Message posted on 16 Oct 2023 10:10 PM
My remote control for the mini box won't switch it on and I've changed the batteries and it still won't work
Message posted on 16 Oct 2023 10:15 PM
Re: Remote control not working
Hi @Mesagooner
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 16 Oct 2023 10:28 PM
I reset it and it's working thanks
