Discussion topic: Remote control not pairing
Message posted on 07 Jun 2024 07:32 PM
My remote will not pair with the SkyQ box. The remote used to turn the tv on and off and control volume but now it does not. I have tried resetting the remote by pressing 7 and 9 and then 1 and 3 but it will not accept 1 and 3 just saying pairing unsuccessful and to try again
Message posted on 07 Jun 2024 07:45 PM
Re: Remote control not pairing
Hi @Owl2820
Try first rebooting your Q
Then with the Q box on with green led try completly resetting your Bluetooth remote.
Message posted on 08 Jun 2024 03:56 AM
Thanks for this. I had rebooted a couple of times following the instructions above. It was successful on the third attempt and only when I held the remote literally 6 inches from the skybox (when pressing 1 and 3). Anyway all working perfectly now thank you
