Discussion topic: Remote can't control Sky Q box
This message was authored by: Moorland2
Got a new remote as the last one stopped working. New one worked for a while, but is now not controlling the box. Have tried doing the 7/9 1/3 reset, the lights flash on the remote but nothing happens with the box. Obviously batteries are new and no buttons stuck.
Re: Remote can't control Sky Q box
@Moorland2 Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Moorland2
Yes done that, also forced the box to an update but still no joy.
