Discussion topic: Remote and q mini box not working
This message was authored by: Gordonwright
Remote was only half working but now can't get the mini box on
Re: Remote and q mini box not working
Hi @Gordonwright
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the Q box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for Gordonwright
Stand by button does not go green it is red .screen saying go to sky.com/software update
I'm confused
How do I go to sky.com/software update when I can't get the mini box on and the remote doesn't work
Did you press the Red Standby on the front of the box to see if this turns it on @Gordonwright
