Discussion topic: Remot
Message posted on 09 Jan 2026 04:55 PM
Remot
My second remote control stops the original working after setup,how can I have them both working?
Message posted on 09 Jan 2026 07:43 PM - last edited: 09 Jan 2026 07:44 PM
Re: Remot
hi @Nobbo
Yes it can be done but rather convoluted.
Note : Only one can be paired in bluetooth mode (& thus Voice control) - the other(s) has(/have) to be IR only
You first pair the one you want to use in infrared only mode (pressing & holding 7 & 9 if needed to reset) by pressing & holding 1 & 3 together & following the on screen instructions
Once paired to the box & TV you reset it to use Infrared by pressing & holding 4 & 6 together
Then you re-pair the one you want to use in bluetooth mode & for voice contro, as above but this time don't press the 4 & 6 after
