Discussion topic: Remite
This message was authored by: Savikar
Remite
Hi my remote is not working
Re: Remite
Hi @Savikar
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Failing that
Check out the following link.
Click still need help and then click get in touch after ticking the box that you have tried online help.   This will lead you to a form for free remote replacement.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
Re: Remite
@Savikar
You'll have to give us more information. Meanwhile see if this link helps.
https://www.sky.com/help/articles/sky-q-remote-help
