Discussion topic: Red light on sky q
Message posted on 28 May 2024 06:15 PM
Red light on sky q
Red light on sky q box not recording anything or anything scheduled , unplugged and left it off for 5 mins turned it back on and red light still on.
any help would be appreciated thanks
Message posted on 28 May 2024 06:24 PM
Re: Red light on sky q
Hi @Pryor
Message posted on 28 May 2024 06:33 PM
Thank you so much. It's worked.
