Discussion topic: Red light on mini box. Main box working fine
This message was authored by: Ginat
Not sure if it's the mini box or remote. Main box and tv working fine
Tried all the usual steps unplugging etc Changed batteries in remote
Have checked services broadband WiFi all fine so am at a loss now what to do
Re: Red light on mini box. Main box working fine
to check if its the remote press the red light as this is also the manual on/off button if it turns the box on then you can try resetting your remote by
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
