Discussion topic: Red button on miniQ box
This message was authored by: Ildi62
I can use a red button for the main Q box ,but not working on the mini Q boxes
This message was authored by: Tennis2000
Re: Red button on miniQ box
I had the same issue so unplugged the mini box and that fixed the issue so try that.
Hi @Ildi62 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
