Discussion topic: Recordings not working
Message posted on 22 Sep 2024 07:19 PM
Sky Q recordings are saying please wait all day, we have tried rebooting several times and catch up isn't working either
Message posted on 22 Sep 2024 07:45 PM
Re: Recordings not working
Hi @JLaw83
Recordings and Catch up are two completely different issues.
Regarding recordings if you also cannot make new ones you may have a hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
Message posted on 22 Sep 2024 07:54 PM
Thanks we will give it a try
