Discussion topic: Recordings finishing early
Message posted on 04 May 2023 02:01 PM
Hi Guys
Does anyone have any experience of your recordings finishing early, before the actualy program finishes..
I have to go back and start the payback again from where it finished, and then it goes all the way to the end of the program.
Its a bit weird but getting annoying now
Chris
Message posted on 04 May 2023 02:03 PM
Re: Recordings finishing early
It's always worth rebooting your Sky Q box for little glitches. Let us know on here if you don't know how to carry that out.
Message posted on 04 May 2023 04:01 PM
Message posted on 04 May 2023 04:22 PM
@Ceeb wrote:
Hi Guys
Chris
@Ceeb You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
