Discussion topic: Recordings disappearing
Message posted on 01 Jul 2024 10:08 PM
Every night at around 9pm for the last 10 days are Sky Q seems to gain a mind of its own. It deletes everything it's recording and all the minis get a "technical fault screen". It's driving us mad. Any ideas?
Message posted on 01 Jul 2024 10:20 PM
Re: Recordings disappearing
Looks like the hard drive may be failing @Bagpuss17278
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
Message posted on 01 Jul 2024 10:34 PM
Was hoping it wasn't this. Will we lose all our old recordings if we swap boxes?
Message posted on 01 Jul 2024 10:40 PM
Certainly will @Bagpuss17278
Any buy and keep from Sky Store can be re downloaded.
Firs thing to try is a reset settings in the hidden menu. This will not not lose any recordings.
If you still have the same issue then you will need to work through the link I posted earlier
