1
This discussion topic has been answered Discussion topic: Recording
This message was authored by: Melissar1
Recording
My sky recordings won't load I've knocked it all etc still won't work
Re: Recording
@Melissar1
Not sure what you mean there.
If you haven’t done it already it may be worth rebooting the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Recording
@Melissar1
