Discussion topic: Recording
Message posted on 18 Nov 2025 09:19 PM
Recording
I have recently down graded my package now when I try to record sky witness or sky Atlantic it won't record WHY
Message posted on 18 Nov 2025 09:23 PM
Re: Recording
Now I've downgraded my package I can't record my witness or sky Atlantic why
Message posted on 18 Nov 2025 09:24 PM - last edited: 18 Nov 2025 09:25 PM
Re: Recording
Hi @Teddypickle Downgraded to what package(s)? For example, those channels are only available with Sky Signature (not Sky Q Essentials).
Message posted on 18 Nov 2025 09:28 PM
Re: Recording
...or did you remove the HD pack? (SD channels may work if so)
Message posted on 19 Nov 2025 09:17 AM
Re: Recording
If you no longer have the HD supplement then it's best to change the default download resolution to SD
To change your download preferences, you need to complete this on the main Sky Q box, not a Sky Q mini box:
Press Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then On Demand default download format, and choose SD
