Discussion topic: Recording
This message was authored by: FizzyS
Recording
Everytime I try to go on my recordings, and try to watch them for some reason a blue screen appears and says 'to watch this channel, please upgrade your subscription'  I have the subscription and the subscription is active but for some reason my recordings don't come on, is there anyway anyone could help.
This message was authored by: Stephen+Mourton
Re: Recording
Have you tried rebooting your SkyQ box?  (Turning it off at the mains, waiting at least 30 seconds and then plugging back in). If so then I can only suggest you ring Sky direct.
Re: Recording
Hi @FizzyS
Avatar for FizzyS
Re: Recording
I've tried all of that, but for some reason' it still won't work
