1
This discussion topic has been answered Discussion topic: Recording traitors uk
This message was authored by: Mike509
My sky will not let me record traitors UK.  The episodes show up 3 days later.is this normal ?
Re: Recording traitors uk
@Mike509
If you are new to the forum or this is your first post then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
No, it's not normal. It’s worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ Using the Sky Q remote put your main Sky Q box into standby
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
@Mike509
