Discussion topic: Recording a prog. without signing.
This message was authored by: Sucrehomme
How can you avoid this happening when setting up a series link?
Avatar for Sucrehomme
Re: Recording a prog. without signing.
Just to be clear, I want to view a prog like Gardeners World WITHOUT the signer at the side of the screen but the series link seems to want to give me the version with the Signer.
This message was authored by: christhedj
The sign language is hard-baked in, usually to a repeat  It sounds like you're recording from a sign language showing. These are usually late at night or early morning.
You'll need to check the "Other Showings" tab and find another showing, ideally the first showing of the week, which wouldn't be signed.
In the case of GW, the 8pm Friday showing is the one to go for.
@Sucrehomme In the synopsis of the broadcast you're recording there should be a 'SL' to indicate Sign Language, so look for a showing that doesn't have that.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
