Discussion topic: Recorded programmes have a green tinge
This message was authored by: pobble
When I replay recodings on my Sky Q set top box they have a green tinge. Watching live TV doesn't. Any suggestions, please?
Re: Recorded programmes have a green tinge
Hi @pobble
