Discussion topic: Reconnect
Message posted on 24 Jul 2024 04:13 PM
Reconnect
Hi
I am having to restart my router everyday to get my sky q to work, I have tried everything online and its ok for a few days then no network connection everyday again please help
Message posted on 24 Jul 2024 05:21 PM
Re: Reconnect
@Sarahl2011 wrote:
Hi
Hi @Sarahl2011
You may have tried already but try completely resetting the connection as follows;-
Failing all the above; if on Sky Broadband you possibly need a Sky Q WiFi booster located between your main Q box and the Sky router. To get one you need to speak directly to Sky.
If you are on 3rd party broadband you cannot connect a Q booster to your router by WiFi but you may be able to connect a booster by a short Ethernet cable.
You would try connecting to this booster following a Network reset on the Q box and using WPS for connecting to Sky device (ie the booster)
