Discussion topic: Reboot failed
Message posted on 05 Nov 2025 10:36 AM
Reboot failed
My Sky mini has failed. It is stuck on the page where it says to press a particular button until it flashes, but it is flashing already and it won't move on to the next page. I have unplugged it, left it for an hour and gone back to it, but the same thing has happened. Any ideas please?
Message posted on 05 Nov 2025 10:41 AM
Re: Reboot failed
Hi @CMC77
Which button is flashing and what colour is it?
Message posted on 06 Nov 2025 04:49 PM
Re: Reboot failed
@CMC77 when is says press the wps button it also says on the nearest piece of q equipment so you need to go to either your n
main b0x another mini box or if you have a black sky router(if your broad band is sky) and press the wps button on the closest one of these boxes to the mini box you are having problems with
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
