Discussion topic: Re: booking an engineer
This message was authored by: DL666
I have Sky Q how do I book an engineer?
Hi @DL666   The obvious question is why, but to answer your question, by contacting Sky. Please note, before you ask, telephone numbers are blocked on this community but can be found on most help pages by expanding Need more help.
@DL666
Your post has been moved from the Sky+ thread you'd added to.
What Sky Q issues do you have?
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for DL666
Hi, because Sky Q keeps freezing when using certain apps and several channels keep saying unavailable and others just won't load. Intermittent connectivity in other rooms etc.  it is a relatively new internet source , but EE advise it's not their internet and speeds are very high . Sky checks through the system say everything is up and running and no issues. Trying to find help through Sky direct is very challenging hence why I've ended up on the furum... hope that helps why.
What version / model Sky Q hox do you have?
Have you tried a settings reset?
