Discussion topic: Re: Sky q mini box not working
Message posted on 21 Nov 2025 10:06 AM
I need a new lead for my sky mini box as the old one is broken
Message posted on 21 Nov 2025 10:08 AM
Contact number
Contact number
Message posted on 21 Nov 2025 10:14 AM - last edited: 21 Nov 2025 10:17 AM
Re: Contact number
I have edited my post as I've found your other post. No need for two threads.
These are the current methods for contacting Sky. Some methods will be more appropriate than others depending on the reason for contact……
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
Message posted on 21 Nov 2025 10:29 AM - last edited: 21 Nov 2025 10:30 AM
hi @sammum
SKY don't normally replace the cables used by mini boxes as these are standard items availble from lots of places, including local stores They all come in a variety of lengths & do not cost more than a few pounds
(Note we, also, do advise customers not to use some of the well known stores that charge 'premium' prices which are not justified)
If it is the mains cable, then look for cables with a standard IEC7 figure of 8
For mini boxes HDMI cables only need to be HDMI V1.4 spec, although most HDMI cables are now HDMI v2.0 or 2.1
For ethernet Cat5e or above is recommended
Message posted on 23 Nov 2025 06:54 PM
New sky box mini
The cable for the sky mini box has become dangerous
Message posted on 23 Nov 2025 07:05 PM
Re: New sky box mini
@sammum wrote:The cable for the sky mini box has become dangerous
Cables rarely become 'dangerous' on their own. Which cable?
Message posted on 23 Nov 2025 07:07 PM
Please see the replies we gave yesterday.
