Discussion topic: Re: Sky Q mini box not connecting
This message was authored by: GJC1
Having gone all winter with no problems the Sky Q mini box came up with no connection 3x in the last week.
Hi @GJC1
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
