Discussion topic: Re: Need an engineer
Message posted on 03 Nov 2025 10:03 PM
Bedroom mini box not working - engineer required
Message posted on 03 Nov 2025 10:11 PM
Call Sky.
Message posted on 04 Nov 2025 11:40 AM
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
