Discussion topic: Re: Mini-box
Message posted on 17 Oct 2023 08:12 AM
Re: Mini-box
Since we upgraded our broadband our sky mini box in our bedroom hasn't worked. We are unable to watch programs on our 2nd TV.
Message posted on 17 Oct 2023 10:40 AM
Re: Mini-box
Reboot the mini as above.
