Discussion topic: Random Reboots
Message posted on 21 May 2024 05:58 PM
Random Reboots
Anyone else getting random reboots to their Q box? Happened twice this afternoon once when sat in standby and another when I was watching Clarkson Farm via Prime Video?
Is the box on its way out? Or are Sky up to something in the background?
Dave
Message posted on 21 May 2024 06:09 PM
Re: Random Reboots
Dave
Nothing Sky are doing @Anonymous
Message posted on 21 May 2024 06:39 PM
Re: Random Reboots
Thanks! I'll do that should it happen again as since I've said about it nothing further has happened 🙄
The cynic in me thought Sky were knobbling the Q boxes so we all change to Stream/Glass 🤣
