Discussion topic: Radio channels are not working on the tv
This message was authored by: Rosemary24
When selected the radio is faltering and intermittent on any radio channel selected
Re: Radio channels are not working on the tv
@Rosemary24
Any error message displayed?
You could perhaps try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Avatar for Rosemary24
Thank you for replying. I have tried that and it hasn't made a difference.
not sure what to do next
