4
This discussion topic has been answered Discussion topic: Racing TV channel 424
This message was authored by: kpyorkie
Picture constantly breaking , or shows satellite signal not available. Recordings jot available, blank screen, on attempt to playback.
Only channel this happens, set up shows good signal.
Avatar for kpyorkie
This message was authored by: kpyorkie Answer
Re: Racing TV channel 424
They're not OK, same problem. Many thanks
This message was authored by: ozsat
Do you have the same issue with TBN on channel 582?
If so you need to call Sky to get your dish alignment checked.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Avatar for kpyorkie
Channel 582 seems perfect
Sorry - was looking at wrong list.
Check channel 513 - TRT World.  Also try 706 and 511.
Avatar for kpyorkie
