Discussion topic: RECORDING,CANCELING AND PAUSING PROGRAMMES
This message was authored by: Brian+of+Sky+Q
LATELY I HAVE BEEN UNABLE TO PAUSE PROGRAMMES, RECORD, OR DELETE KEEP GETTING ... THERE IS
A TECHNICAL PROBLEM WITH THIS CHANNEL OR YOU ARE UNABLE TO PAUSE THIS PROGRAMME.
ALSO WHEN I SCROLL TO A NEW CHANNEL THE SCREEN JUST REMAINS BLU I HAVE TO PRESS CENTRE
BUTTON ON REMOTE AND PROGRAMME THEN COMES UP. THE PROBLEM DOES CLEAR IS I REBOOT
SYSTEM BUT 2 DAYS LATER SAME PROBLEM SURFACES
This message was authored by: PeteRG41
Re: RECORDING,CANCELING AND PAUSING PROGRAMMES
Check that your Sky Q box isn't overheating.  Check the ventilation ports for dust and do what you can to clear/blow them clear.  Make sure where your box is has plenty of ventilation.
If it's all clear, then possibly reporting this to Sky will result in a replacement Sky Q box.
____
Pete.
