Discussion topic: RANDOM RECORDINGS
Message posted on 25 Nov 2025 01:55 PM
RANDOM RECORDINGS
My SKY box is recording completely random programmes unprompted and unshceduled. Why is it doing this and how do I stop it? Today an episode of I'M A CELEBRITY GET ME OUT OF HERE arrived on my planner, which was the last straw !!! Help 😉
Message posted on 25 Nov 2025 02:16 PM
Re: RANDOM RECORDINGS
Recordings can only really be scheduled if someone presses the record button on the remote control or via the Sky Go app.
Recordings can also happen if you recorded a series last year, the series link should pick things up when the next series comes up.
You can check what's scheduled for future recording by going into Recordings and then Scheduled. From there, you will be able to remove a series link for anything you don't want to continue with and cancel the actual recording.
Its up to you to find out who in your household is scheduling these recordings I'm afraid.
Pete.
Message posted on 25 Nov 2025 02:21 PM - last edited: 25 Nov 2025 02:21 PM
I've had it happen as well although rarely. I'd asked my wife as well who has denied all knowledge.
It may be a change in the programme schedule on the epg and instead of recording something you've set up, it records the newly inserted programme.
Theres not really a lot you can do about it I'm afraid.
Message posted on 26 Nov 2025 12:24 PM
Thanks for preuming I am stupid mate! Fair enough under normal circumstances perhaps, but on this occassion there is definitely a glitch in the matrix I assure you 🙂
Message posted on 26 Nov 2025 12:25 PM
Sounds like we share a poltergeist in the system... Thanks for hitting me back anyways 🙂
Message posted on 27 Nov 2025 07:09 PM
Do you have a pet?
Our cat will often press the remote & recently set a program to record & set the series link, he's only stretching.
I don’t work for Sky.
If I have helped then please leave a like.
