Discussion topic: Qvc pixelating
Message posted on 27 Aug 2025 10:39 AM
Qvc pixelating
These channels are pixelating through all kinds of weather. Is there a solution to this?
Message posted on 27 Aug 2025 10:41 AM
Re: Qvc pixelating
Hi @Joyte12 Yes, contact Sky and book an installer to realign your dish.
Message posted on 27 Aug 2025 10:43 AM
Re: Qvc pixelating
@Joyte12
Check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
