Discussion topic: Quality issues when downloading
Message posted on 13 Nov 2023 07:33 PM
When I download anything the picture is a a mix of colours and not watchable
This has also affected other downloaded programmes that were recently watched. This does not seem to be happening if live tv is recorded. Please confirm how I fix this.
Message posted on 13 Nov 2023 07:44 PM
Re: Quality issues when downloading
Hi @Gayle2
Looks like you Q box is not fully connecting to your Broadband.
You could first try a Reset Settings on the Q box to see if this improves.
Reset Settings in the main Q box hidden menu.
If the reset settings hasn't helped then try rebooting your Router. Disconnect power lead for 30 sec and then reconnect to reboot.
Then
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
