Discussion topic: Qbox
Message posted on 05 Sep 2024 09:57 AM
Qbox
Qbox cuts off connection with message problem finding Qbox on network. Switching Qbox off then connecting again gives connection for approx 5 minutes then cuts off again. Repeating switch off again gets same result each time. No problem on main box or on WiFi connection. ?
Message posted on 05 Sep 2024 10:06 AM
Re: Qbox
This is wifi connection on mini box?
What sort of wifi do you have? Any mesh for example?
Message posted on 05 Sep 2024 10:19 AM
Re: Qbox
Hi @12a
Try completly resetting the mini connection.
Carry out a Network Reset on the mini.
Message posted on 05 Sep 2024 04:26 PM
Re: Qbox
Thanks 4 that. I'd tried that several times but no good, back to square one, then tried again this morning and it came back to say can't find IP Address & was WiFi on. - it was. I clicked yes & lo! It switched straight to a picture & has been ok all day! Thanks again for replying.
