Discussion topic: Q multi box problem
This message was authored by: Brynymor21
Q multi box problem
I have a problem with tv programmes
message says programmes in svsilable
tried everything recommended
Re: Q multi box problem
Hi @Brynymor21
Reboot the mini as above.
