8
This discussion topic has been answered Discussion topic: Q box
This message was authored by: Gill126
Q box
Sky Q light off but box is on
Re: Q box
@Gill126 wrote:
Cannot seem to connect to internet now. All other products are okay.
Hi @Gill126
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Re: Q box
Hi @Gill126
Central blue Sky Q light only shows on playback of recordings or reboot.
Power light is green led on front right of Q box.
Avatar for Gill126
Re: Q box
Thank you
Avatar for Gill126
Re: Q box
Re: Q box
Hi @Gill126
Avatar for Gill126
Re: Q box
Great thank you very much. Sorted
This message was authored by: Dodger3101
Re: Q box
No my sky box needs replacing the hardrive does not work
Re: Q box
@Dodger3101
Try following this link. It should lead to a replacement box if needed https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box before it disappears into the back of the couriers van and accept any new power cable DPD deliver with the replacement box in case it's different to the one you have.
Re: Q box
@Dodger3101 follow the link below and it should lead you to requesting a replacement box
https://www.sky.com/help/sky-tv/sky-tv-q/fixing-sky-q/an-on-screen-message-sky-q/articles/sky-q-hard...
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
