Discussion topic: Q box
Message posted on 22 Apr 2024 12:52 PM
Q box
Good afternoon. My sky box was not recording correctly or playing back in an effective way. I conducted a 'soft restart' and after initial investigations, realised this did not resolve the issue. I have completed a full restart/reboot (which I was.not entirely happy with as I lost all recording) but this has not resolved the issue. I am now receiving messages when changing channels or trying to either record or.playback stating 'there is a technical fault with the Hard Drive'. I suspect the age of the skybox has caught up with it.
Message posted on 22 Apr 2024 01:39 PM
Re: Q box
@JamesdixonhunteYeah it sounds like the hard drive is on its last legs. Relaistically will be a box swap now. Best thing is to call sky.
Message posted on 22 Apr 2024 02:44 PM
Re: Q box
Assuming from what you have tried above, you have done a reset hard drive as described in the Sky help article below.
If you have and still getting a hard drive issue message, you can order a replacement Sky Q box online, details in the Sky help article below;
Make sure when you return your current Sky Q box to the courier that you remove your current Sky viewing card as you will need that for the new replacement box.
https://www.sky.com/help/articles/fix-recording-problems-on-sky-q-other-recordings-problems
