This discussion topic has been answered Discussion topic: Q+ box will not switch on either manually or remotely
Message posted on 06 Mar 2025 10:10 AM
Q+ box will neitherswitch on manually or remotely
Message posted on 06 Mar 2025 10:51 AM
Hi @GraigF
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Hi @GraigF
Message posted on 06 Mar 2025 01:14 PM
Re: Q+ box will not switch on either manually or remotely
@GraigF wrote:Q+ box will neitherswitch on manually or remotely
Note it's either a Sky Q box or a Sky+HD box (there's no such thing as Q+)
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
