Discussion topic: Q box problem
Message posted on 02 Sep 2024 08:34 PM
Q box problem
Haveing To turn box off at the mains to reset after freezing. Unit has started pixolating randomly.
Tonight after another restart we have lost all record programs on the box. We've got very good Internet 300 meg
Message posted on 02 Sep 2024 08:37 PM
Re: Q box problem
Hi @fafellows1 .
