Discussion topic: Q box not responding
Message posted on 25 Nov 2024 08:30 PM
Message posted on 25 Nov 2024 08:46 PM
Re: Q box not responding
@Catherinetnr wrote:
The sky q box isn't working I've unplugged it restarted it held on the sky button while it was a blue ,Q the other light on amber then the W turns red and won't respond
There is no process where you hold the Sky button.
Try another reboot.
Have you tried rebooting your Q box?
If you had to press the Standby button on the front of the Q box to bring it on try the following.
