Discussion topic: Q box freezing
This message was authored by: Josephgreen
Q box freezing
Have 2 Q boxes one keeps freezing tried all methods surgested to rectify but no luck if not rectified will finish agreement with sky and go to freeview
Re: Q box freezing
@Josephgreen
Threatening to terminate your subscription is pointless here. You aren’t communicating with Sky, this is a customer ➡️ customer discussion forum where we try to help other Sky customers.
You probably won't be able to cancel anyway. The latest T’s and C’s explicitly state you can’t cancel when still in a minimum term deal unless Sky agree.
What have you tried? Have you contacted Sky and gone through any troubleshooting with an agent? Have you used Sky Assistant available via
https://www.sky.com/help
which is available for most service issues and gives you 24/7 help and a quick response. It should provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
Re: Q box freezing
Hi @Josephgreen
Assume the box that keeps freezing is a Sky Q mini.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
